best TV for gaming?
dangalf
85
Hi all
Was wondering if anyone could recommend a TV for gaming (PS3). Am looking to spend about £500. This TV will be used for gaming only. Am looking for around 26-32 inch set
Have been trawling thru magazines and the two that stand out in this price bracket are:
Panasonic TX26LXD70 and Samsung LE32R87BD
Just not sure sure if they were good for gaming - and if they're not what's the best TV out there?
Andy Clough
776
I'd go for the Panasonic. Here's why:
"Its fast screen response means it will suit even gamers, offering ample insight into all those dark caverns where monstrous thingies with sharp teeth just love to lurk!"
What Hi-Fi? Sound and Vision, December 2007
dangalf
85
Thanks for the info Andy and thanks for the speedy reply. Will probably buy the Panasonic now
Cheers!
Clare Newsome
1,657
The added advantage of the Panasonic is that it'll accept your PS3's 1080p feed natively, without you having to set the Sony to output at a lower resolution (which is the case with the Samsung).
Is it the case then that its better to for your tv to downscale natively than to get your ps3 to do the work? Is this the case for most sources and tv's if so why? I'm looking to get the panasonic TH-37PX70 and PS3 would it be best for the tv to downscale then the ps3?
is the panny pz70 better than pio 428xd for gamng----- due to native res???
