Best software for a FLAC library?
Hi there,
I was wondering what software interface is the best for Flac files? I really (really really) like iTunes layout, its logical and easy to burn CDs, make playlists etc. I no longer use an iPod, but want to get a Cowon, so I am using Flac instead of apple lossless. The sound quality is just so much better with the Cowon. What software (for Vista) would others recommend? Freeware would be best...Im currently using Foobar2000 but its pretty plain, and I don't think you can even burn CDs?
Thanks for your replys. Im ripping CDs with EAC straight to Flac.
Foobar is definately not plain, it's very configurable but does need a bit of time to understand .. Take a look at PJPRO's guide (link in his sig.) should help you get started. Foobar can burn CD's convert to other formats etc.
