Best Sky HD settings for 1366x768 HD Ready LCD: should it be 720p (instead of 1080i)?
nickers1969
19
I've tried both and can't see any noticeable difference in quality with either SD or HD broadcasts!
I suggest try them and see which you prefer! And let me know what you think!
You can't see the difference between HD and SD broadcasts ? That's worrying!
I leave mine on automatic so the TV adjusts to whatever resolution it receives, that means 576 for SD, 720p for Sky Sports and 1080i for the movies and some other channels.
If you set it to 720p or 1080i, will it upscale SD signals?
Also if you set it to 720p or 1080i will it switch between the two when Sky broadcasts different hi def signals, i have never tried it out so dont know
