- Dec 5, 2014
- 3
- 0
- 0
As the title suggested, I am looking for what you guys consider to be the best pair of over-ear open-back headphones from 100-200$. I'm currently using the Audio Technica ath-m40x's and I'm pretty satisfied with the sound but as I said I want something open preferably with a wider soundstage and more open sound. I've been looking at the Sennheiser HD598 for quite some time but I've been hearing some pretty mixed opinions about those. Is there anything else that you guys would recommend at around the same price? Comfort is also important. I've owned some cheaper Sennheiser headphones in the past and I've always enjoyed the sound of those but I'd expect the HD598's to be a lot better. I will only use these headphones at home as well so portability isn't important. Any suggestions or should I go with the HD598's?
