- Aug 10, 2019
- 2,556
- 5
- 0
I posted on a similar vein to this in the Hi fi forum but had no opinions in reply
Essentially I am running a B and W Home theatre 685 system with an upgraded CM1 centre speaker driven by a Denon 2309 ( the previoius model to its acclaimed younger brother ) the 685 fronts are bi amped, my source is a Pana BD 35.
Biggish Room 7 m x 4 m
All well and good- but at this price point you compromise the stereo sound at two levels - transport and amp.
So plan B is to add a Naim CD5X and Nait xs with its av bypass function which will drive the front speakers. I would like to replace the 685's with the Spendor A 6'S , using the 685's as rears in a revised surround set up . Spendors are not bi wireable so my thinking is that I can use the Denon to drive the rears as if they were fronts and they can then be bi wired.
Questions a) Can this be done b) will the crossover mix of Spendor and B and W work c) is the av bypass function going to deliver a Naim sound through my Spendors d) Do I have to revise the connections from my Sky HD to the Denon amp so that the Spendors are used or is that all covered by the right input/ output on the XS by pass
Answers/ Comments please
