skipper said:Thanks for the suggestions,folks
MUSICRAFT said:Hi Thompsonuxb
Fwiw, i also use basic interconnects between a Chord Electronics QBD76 & a Plinius Hiato, Densen B-420 XS & B-175 Plus, etc. and at the moment i've got a system playing in the background which consists of a Plinius Odean connected to Monitor Audio's Platinum PL300AV speaker system using just standard 79 & 500 strand OFC speaker cables
All the best
Rick @ Musicraft
All the best
Rick @ Musicraft
Thompsonuxb said:MUSICRAFT said:Hi Thompsonuxb
All the best
Rick @ Musicraft
Sorry for dragging this back up but I'm curious.
Rick do you choose to use cheap interconnects or do you genuinly hear no difference between cables, or do you hear the difference but don't consider the gains worth the spend. I know we all have our 'own' ways of listening and hearing our music. But thats alot of spend on equ with what looks like not wanting to get the best from them.
whats your story?
MUSICRAFT said:Thompsonuxb said:MUSICRAFT said:Hi Thompsonuxb
All the best
Rick @ Musicraft
whats your story?
Hi Thompsonuxb
Keep it simple and your components/system will breathe. Simple is best
All the best
Rick @ Musicraft
Cypher said:I tried several cables in the past and they all sound the same to me.
Ever heard of the term psychoacoustics ?
http://www.sound-remedies.com/psyc.html
moon said:now you sound confrontational
Cypher said:moon said:now you sound confrontational
We just disagree on something. Not a problem at all...........it would be very boring if everyone had the same opinion![]()
Thompsonuxb said:MUSICRAFT said:Thompsonuxb said:MUSICRAFT said:Hi Thompsonuxb
All the best
Rick @ Musicraft
whats your story?
Hi Thompsonuxb
All the best
Rick @ Musicraft
Trying not to sound confrontational....... but that makes no sense, before I discovered the wonders of a decent intercoonect I was happy to be 'dissatisfied' never really feeling my music and not really knowing why ( I actually sit and listen to my music, its not background noise).
I can understand some really not being able to hear differences and others liking a certain sound from their system. In the same way some people are colour blind or hate the colour yellow, but I'm flabbergasted you have a shop and would take such a stance when interconnects can make a good system a great one.
Honestly this is not in any way confrontational, I'm curious.
