Best Google Assistant speakers 2020: best Google smart speakers
dbent1856
How can you rank the Sonos one as the top speaker for Google assistant when it barely works? I bought this speaker based upon your 2020 review of the same and it is a disaster. With tidal, you cannot even use the tidal app. You must use the sonos app to play on tidal and it does not recognize tidal as an option for voice control...so requesting the speaker to play a song is a complete no go. I wish I would not have bought it. I already had the sub, the playbar at two ones in my room upstairs so I thought great! Just add another sonos. This thing sounds good but the interface sucks. I cannot believe you ranked it first. Just go look at the reviews on sonos. They are awful. One star. Almost all of them. You really need to spend more time with these devices before you recommend them so highly.
E8link
You should revisit the recommendations for compatibility with google assistant. Sonos - no chrome cast grouping - same with Bose. Very few supported music providers with Google - Apple Music, etc.
I think you are just basing the recommendations on sound quality not actual compatibility with Google assistant.
joan38
Sonos and Google are the best enemies. They has a big lawsuit about the cast feature (https://www.theverge.com/2023/5/26/23739273/google-sonos-smart-speaker-patent-lawsuit-ruling).
Sonos is actively trying to not work with Google. They do not support casting audio. Nothing really works with Google product and every Sonos owners is complaining (https://en.community.sonos.com/smar...8/add-chromecast-built-in-integration-6863783).
So how is this test showing the top 2 as Sonos speakers for Google Assistant? Well because
Harry McKerrell
Harry McKerrell received a good check from Sonos obviously!
