best amp for ma rs6
hi
I'm looking for stereo amp for my monitor audio rs6 loudspeakers.
i'm thinking about old cyrus6, marantz 8003, rotel 1520, cambridge audio 840 or yamaha a-s1000. Which from them will be the best for my loudspeakers. Maybe is not worth buy that expensive amp and I should by nad 326 or 355, c-a 650, marantz 6003 or 7003 my room -30m2. I listen to all type of music.
thank you.
vinod_david
150
38
18,620
Hi:
IMO, please avoid Cyrus, Rotel, Naim, could sound bright and unpleasant.
Having said that, the CA 840 v1/v2 or the 8003 is a very good match for the RS6 - I would suggest the 840.
If you have budget for 840 and 8003, go for it. The RS6 needs better amps to drive them.
vinod_david
150
38
18,620
ear:do you think they dont sound good with the ca640?
After using 640+RS6 combo for more than a year, I can safely say the 640 is very underpowered for the RS6. I guess 740/840 can have a good grip of the RS6. IMO.
tomaszurb:
hi
thank you.
I'm currently testing a Creek Evo 2 and the synergy is fabulous. As regards Cyrus, yes depending on your source. When I tested the 8VS2 on my system it sounded really top notch.
A budget Nad will drive RS6s well, unless you live in a converted barn. Personally, I would look at the high end Arcam DIVA range, like A85 or A90. Perfect. Alternatively, Roksan Kandy has really good synergy with RS6, also Exposure 2010S will work well.
Arcam
Roksan
Creek
Exposure
d_a_n1979
134
Yup; as above, a decent Arcam amp would be very good with the M/A RS6's (i.e. Arcam A85, Alpha 10 or A32 via eBay)
If you want new then I'd highly suggest the NAD C355BEE integrated; superb amp and would drive the M/A RS6's with ease
Personally I dont feel C/A amps do as good a job with the M/A RS6's as the Arcam or NAD amps do; to me they sounded a bit thin and clinical.
It would be handy to know what music you generally listen to and also what your source is?
Gerrardasnails
295
tomaszurb:
hi
thank you.
I first used a Creek Evo with mine and it sounded brilliant. I was forced to change and I got my 840A v1. This is an even better amp and contrary to what some people say, they match up great. For the record, I use the balanced connection from amp to DAC.
Hi tomaszurb
I have mine connected to a NAD 352 and it sounds really clean and detailed. I am really happy with the sound.
