Best 3.5mm jack to 3.5mm jack?
Basically I'm
Connecting a radio to my airport express through a mini jack I'm also probably use it through other sources to computer etc any ideas no budget thanks
Messiah
205
10
18,795
Can you connect a radio to an AE?
You might be able to connect an AE to a radio? (Still same connection mind you...)
What Radio do you have?
Not to worry had a lot of problems with radio so taking it back not only does it seem to be a x display when it suppose to be new I connected through a belkin 3.5 jack to airport express just to try it out for the time being and it generally struggles/strains with volume! And the wire has nothing to do with it as I used it before it's a good/standard wire thanks for yr replies though!!
