Gerrardasnails:chainrock:
Craig M.: i personally think the beresford is "better", but it depends on the sound you get from your other components as to wether it will suit you.
And this comes from a DacMagic user!
My system is quite lean with good midrange already, so in this case I should stick to DacMagic. Or maybe Caiman sounds really good?!
Hifinewbie - I contacted mr Stan about a trial of Caiman but never got a response.
Yes, Craig, explanation?? Why have you got the DM if you think that the Beresford is better and it's cheaper??
i was talking about the 7520 (i had both, just sold the 7510). i do think that the beresford has more going for it, in it's areas of strength i think it's astonishing for the money, but i had better system synergy with my old focus 110's. with the atc's i found the bass to be a touch lean for my taste, they also revealed the beresfords treble to be a little unrefined (can't think of a better way to describe, there's just something about it that's not right). the dacmagic doesn't sound as accurate or revealing as the beresford, but it does seem more musical and a bit more fun, and also covers up a bad recording a little bit. having said that it's a temporary measure, and i will be checking out the naim dac and cyrus dac x, if neither appeal i might take a punt on a chord dac64 or see if i can get a benchmark on home dem.
edit to add, i'm using the min filter setting most of the time. i only use linear if the music has a lot of bass and is well recorded, otherwise min is more musical and fun for me.
