Bel Canto DACs
acalex
73
Good morning everybody,
Did any of you have any opportunity to try any of Bel Canto DACs? If so what do you think in terms of sonic performances?
I have opportunity to pick up a Bel Canto 3 at a great price as a second hand item.
The DAC will be the centre of my digital source (cd player, pc, streamer). This will be till I can't prove that a Linn DS product is a better product for the same money (a direct comparison is required).
Thanks for your thoughts as usual!
CnoEvil
556
11
I have briefly heard it and think it is good enough to be on your shortlist.
I found it clean, detailed and neutral without being aggressive. There was a slight leanness to the bass, but it was tight and well controlled.
This was a first impression and might not be totally accurate....from what I heard, I would find the DS a little more musical, with a bit more "body" to the sound.
SonofSun
CnoEvil said:
I have briefly heard it and think it is good enough to be on your shortlist. I found it clean, detailed and neutral without being aggressive. There was a slight leanness to the bass, but it was tight and well controlled. This was a first impression and might not be totally accurate....from what I heard, I would find the DS a little more musical, with a bit more "body" to the sound.
I take it you heard it with your own system?
Gerrardasnails
295
I think your speakers need to be the Sonus Fabers and not the RX6s to hear how good a DAC of that level is. I was close to getting the BC 1.5 before getting my Moon. There are some great boxes at that price range.
acalex
73
Thanks for your insight as usual. I indeed asked my dealer if it would be possible to have a demo unit to try. very curios to see how it would perform. Compating it with a DS would be relatively easy as there is a great shop here in Bx with all the DS product range
CnoEvil
556
11
No, it was at the dealer. From memory, it was through a Bel Canto amp and Focal speakers.
It was a brief listen, which is why I added the caveat in my post. I would feel more comfortable if someone who actually owns one, gave a more informed view.
acalex
73
On that I agree fully. I will indeed try any DAC through the Sonus Faber which are on paper "my speakers" already :)
