Beginner System
jaz9090
6
Hello, I am a student and a relative beginner to all this kind of stuff. I have always loved music and being a musician love to hear music reproduced to a very high quality. A couple of years ago I replaced my ipod headphones with some etymotic er6i earphones and was blown away by the quality of the sound reproduction through them. Whilst at uni I have bought some a sound blaster z680 surround sound system which when i had problems with it was replaced with a z5500 system. These are ok but i dont think brilliant for reproduction (they are after all pimped up computer speakers) - i should really upgrade the cables. Anyway I currently have about £500 to spend and I am looking to get some really high quality output for my music. With that budget I won't be able to get much on the hifi system front (correct me if I am wrong) so i thought perhaps headphones and a headphone amp (from what I have read) this is what i am thinking: A pair of Gradi SR325i headphones A Creek OBH21SE Headphone Amplifier I should say that most of my music is on my macbook/ipod and on cds played via my macbook or ripped onto there. Is the laptop too large of a bottleneck for decent sound quality? and am i right in thinking £500 is just to little to buy any sort of decent system what do you recommend? Thanks, hope that all makes sense James
Hi James,
Honestly, don't put yourself down over your budget. When I was at uni I certainly didn't have £500 to play with! And with that money you can actually do pretty well hi-fi wise.
If you check out the latest issue of the magazine, you'll see we did a one-make hi-fi test, in which a £450 Cambridge Audio system is awarded a full five-stars. A system like that will sound great if you play your CDs straight through it, and the amp and speakers will have a good stab at your digital collection, too.
If you still think the headphone route is better for you, you can get great sound for £500. The Grado headphones and Creek amp you've mentioned will do the job nicely.
Overall, there's nothing wrong with playing music from a laptop, but try to keep the compression to a minimum. Go with WAV encoding if possible, and if hard disk space is an issue, put aside some of your budget for a new hard drive. Shop around and you'll be able to pick up a 500gb external unit from a decent company for under £70.
While you're on the subject, I should mention that you can compress your audio files with either FLAC or Apple Lossless Codec (for iPod compatibility), which will reduce them to about 40-50% of their WAV size, while still maintaining identical audio quality. They are sort of like audiophile versions of the MP3 format, and come highly recommended.
