Bathroom Wall Mounted Speakers
piper1st
I am after a pair of bathroom wall mounted speakers. The criteria is simple, but i am really struggling to find something suitable. I am looking for ...
+ Suitable for Bathrooms Use - wall mountable
+ Cheap - less than £100 for the pair
+ Small
+ Good enough sound without a subwoofer
+ Interesting shape - sphere or cube
Something like high gloss white would be ideal, but i suppose i would really be chancing my arm with that.
Has anyone got any suggestions for me? :?
Cheers for that matthaskell, those JBL Control One AW's look a good option. Had a look into them ... they are £30 over budget, but look like good kit. I can't find any reviews for them though ... are you (or anyone else) using them? Or heard them?
Hi, I havent personally heard them or any outdoor speaker in fact.
But I would trust jbls reputation.
Acoustic energy also produce outdoor speakers.
Just thought it may be worth a look.
Matt
Cheers again Matt. Yeah, i've seen a pair of bathroom speakers for as little as £30, and considering them as the acoustics of a bathroom is exactly brilliant anyway. But fell into the trap of the "buy cheap, buy twice" in the past.
Anyone more input from anyone else using moisture resistant speakers?
BUMP, i don't suppose anyone has any positive/negative comments on budget outdoor speakers for my bathroom?
