Bass, Treble and Balance not working on amp??
AngusM
Hi
I have an Arcam Alpha 7 amp. I was only receivng output on one of my speakers (apart from when I pressed the top of the amp). When I did this both speakers worked fine. I suspected a loose connection so I opened up the amp to see if there was anything obvious. I couldnt see anything but now my bass, treble and balance don't work. Grateful for any help?
thanks
If the above does not work, i would imagine there is a lead that goes to a board behind the bass treble balance knobs, remove all the dust first then re seat the connector.
David@FrankHarvey said:
Is the 'direct' button pressed in?
My immediate thought when I saw the title.
When the direct button is pressed in they are disabled. I always listened to my Alpha 9 with the direct button on because it sounded better to me.
