- Jun 24, 2009
- 22
- 0
- 0
wondering what the general concensus is on blowing at least 25% of speaker cable budget on banana plugs ? are they worth it or would you rather spend on better quality unterminated cable ? also should they only be bought if professionaly fitted ? i have used basic ones before only as convenience rather than sonic qualities.
please no replys from the ' i dont believe in cable makes a difference ' cynics. i dont share your view and there is enough threads already!
