Hi Have just bought four gold plated banana plugs from Maplin to connect speaker cable to my Rotel RA-01 amp but they don't fit. Even with moderate pressure,they seem to big.
Maplin Part No. L86AZ
http://www.maplin.co.uk/Module.aspx?ModuleNo=44115
The Rotel manual states that 'dual banana type' connectors can be used but I think this is referring to 2 plugs joined together. I tried an old 'split' type plug which fits ok but really want to use the gold plated banana type. Plus i've now opened the packets.
Is there a particular type of banana plug I should be using? Any help appreciated.
Dan
Dan
