Muzza said:Hi
Does anyone know if these are due to be updated anytime soon as they seem to have been around for ages? Also are they the best option at around £1,500 for a combination of films and music. The room is quite small so large speaker packages are out.
MUSICRAFT said:Muzza said:Hi
Hi Muzza
What AV amp will you be using?
Music - What do you and anyone else who is also likely to use the system generally listen to?
The speaker cables which you'll use are?
What kind of presentation are you looking for from the speakers and the system as a whole to reproduce?
All the best
Rick @ Musicraft
Muzza said:Hi Rick
The amp and cables need to be chosen too, but I think maybe one of the Onkyo or Yamaha 2011 models as I like the Spotify option. As for types of music its a mix of rock and salsa (wife's South American!), any ideas?
Apologies I am not sure what you mean by presentation?
Hi Muzza
All the best
Rick @ Musicraft
buzz_lightclick said:@pppp1
You may have a scoop over What Hi-Fi there! I wonder if it's just the PV subwoofer they are updating for the new system or if the M1 sats are finally getting a make-over.
FrankHarveyHiFi said:Other than they're going to be updated, I honestly don't know anything else. I suspect we'll hear more over the next few months. As and when, we will!
