If I recall correctly, the cables m the amp connect to your sub, then all speaker cables run out from the subwoofer. The crossover frequency will be set quite high as the M Cubes are NXT speakers, so you'll find that crossover point won't allow other normal speakers to run at their optimum. You would be better off replacing the whole speaker system
