Hi guys.
I'm in a position where I can get the B&W 685 with a pretty nice rebate, making it equal in price as the Dali Lektor 2. Here in Norway these two are usually like $150 apart, which of course makes me want to snap-buy the B&W while the offer stands.
But is it really better though, or is it just a subjective matter of taste? What is the difference between these in general? I heard the 685 is a little weak in the middle tones, where the Dali is supposed to be excellent. This worries me a little, but then again I know nothing about this stuff -- and even less about how all that could change with the choice of amp I make.
I'm planning to use the speakers with a budget amp, like the NAD C316 or possibly C326 (but not anything more expensive). For now I will hook up my iPhone for music and use it with my HDTV for movies. I plan to add a CD player and/or dock later.
Is there other amps that could be better match-ups for each of these speakers? And will one of the speakers require a better amp than the other to sound good? I want to buy from my local shop, so I have to choose between NAD, Cambridge and Denon for amps, and Dali and B&W for speakers.
Sorry for so many questions -- any help is very much appreciated!
EDIT: One other thing. Would it possibly make sense to not choose any of these speakers but instead go for a cheaper one like the Lektor 1 or Concept, and then use the spare money on a better amp? Is it better to go cheap speaker + expensive amp then the other way around? Sorry if this question is dumb.
