B&O H6 for £179!!
bay24
160
If you can take the colour these B&O H6 seem like a steal!
http://homeavdirect.co.uk/bang-olufsen-h6-limited-edition-by-ricarso-akn
bay24
160
I would not necessarily agree with the sound quality comment, they do have a different presentation but I wouldn't say they have better sound quality. The grados are also no good if you want to listen to your music anywhere that isn't quiet or on your own. The build quality and comfort on the grados are also not great. £80 more doesn't seem a huge amount more for the above bonuses to me.
Marsbardark
35
I agree grados environment usage limitations need to be considered, but having tried a friends pair of these plus similar offerings from b&w, they are just overpriced nice feeling and looking headphones. Please enlighten me to any B&O product that is worth its RRP for its sound or picture performance.
bay24
160
bigboss said:
Marsbardark said:
Not really, a pair of Grado SR80i's will sound better.
That's such a non-sensical statement. That's a very good price for B&O H6, considering it retails at £329. I personally didn't like the Grados at all.
I agree, they are very different products. I do like the grado sound though.
Deleted member 2457
I still can't decide what to do with headphones! :wall: I prefer on the ear ones though, so think I will pass, but tempted though. :)
Deleted member 2457
Marsbardark said:
No ****! Gel you have a subwoofer that cost more than my whole signature, can't you just be happy with what you've got?
Yep, good advice. :). I just can't make up my mind with headphones though, I got a pair from Tesco for £25 down from £60 and they hurt my head - not soft enough, now I know I will buy a pair but what I am not sure. Best I avoid spending over £100 though. I would like to find a bargain from somewhere though. That would be sweet. :grin:
Deleted member 2457
Marsbardark said:
What do you want the headphones for?
While on holiday and home use. I was thinking about the Philips M1 at £105?
Marsbardark
35
http://www.amazon.co.uk/Philips-L1-00-Fidelity-Headphones-Black/dp/B0066XYIJ4/ref=sr_1_2?ie=UTF8&qid=1404595463&sr=8-2&keywords=philips+x1
You really don't know much about B&O then. They're not mere style statements. They inveat in a lot of R&D. They invented class D amplification.
http://en.m.wikipedia.org/wiki/ICEpower
Compared to the cheap brands who mass produce stuff by buying components from other manufacturers, B&O makes most components in-house. Their products are known to last for 20+ years. Their build quality is second to none. B&O Avant TV for example doesn't use cheap plastic, it's made of aluminum and glass.
Check this:
http://www.faqs.org/patents/assignee/bang-olufsen-as/
And this:
http://www.danishnet.com/info.php/products/bang-olufsen-256.html
Check B&O H6 review here:
http://www.whathifi.com/forum/headphones-etc/bang-and-olufsen-bo-stereo-headphone-review
Deleted member 2457
I prefer on the ear headphones, got any of them? :cheers:
richardw42
299
I think they must be finding the blue ones hard to shift as they are £179.90 on Amazon.
The black ones are over £100 more.
I quite like like the blue one and I might order a pair as I find my AKGs a bit uncomfortable.
It's the same seller on amazon.
richardw42
299
Hadn't noticed :)
I'd happily pay the extra 90 p thru the Amazon site. When ever I've had an issue with a seller on Amazon they've always reacted wel. I think they're likely to act quicker to retain their status on he site.
Deleted member 2457
I ordered mine on Amazon, that way if you change your mind your can cancel. Just got a pair for £20 on John Lewis clearance, this pair here:
http://www.johnlewis.com/john-lewis-spectrum-on-ear-headphones-with-mic-remote/p809065?colour=Gunmetal
They were £50. Pretty good too and you get a case.
ASK THE COMMUNITY
