A admin_exported New member Aug 10, 2019 2,556 5 0 Dec 9, 2009 #1 Dear What Hi Fi, why cant i load a photo into my my avatar. Anyone else have this problem?
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Dec 9, 2009 #2 yes everybody, do a search for avatar, this has come up several times in the last few weeks.
A Anonymous Guest Dec 9, 2009 #3 Yea think they are too busy sending multiple e-mails about best blu-ray players
Dave_ Well-known member Jul 31, 2008 1,620 916 20,570 Dec 9, 2009 #6 Well if you do a forum search you'll find the answer on how to get your avatar uploaded!!!! Try this thread for example.
A Anonymous Guest Dec 9, 2009 #9 Naw just a photo of one of my guitars. sad really but its my thing ha ha
T The_Lhc Well-known member Oct 16, 2008 1,176 1 19,195 Dec 9, 2009 #10 johnnyjazz:STILL NO REPLY I told you what to do, search for the other threads, the instructions are in there.
A Andrew Everard New member May 30, 2007 1,878 2 0 Dec 9, 2009 #11 email us the picture at this address with 'johnnyjazz avatar' as the subject, and I'll sort it.
A Anonymous Guest Dec 9, 2009 #12 can I send one too? ... if so, does it have to be a specific size as I do not know how to make the size smaller
A Andrew Everard New member May 30, 2007 1,878 2 0 Dec 9, 2009 #13 yes, but of course put 'dim_span avatar' as the subject. And don't worry, I will resize it
S Sabby New member Jul 22, 2009 36 0 0 Dec 11, 2009 #18 Hi Andrew Many thanks for uploading my Avatar.
