AV Sender
vpacalypse
149
I'm after an AVsender & not sure about which one will suit my purpose. I want it to output a signal from sky+hd to another TV I have which is two walls away (maybe 3 since I'm deciding to move the TV again).
I'm looking into this presently:
http://www.amazon.co.uk/Qose-5-8Ghz-Wireless-Sender-receiver/dp/B003CYYR4Q/ref=sr_1_1?ie=UTF8&qid=1349126123&sr=8-1
Any good?
Anything out there representing better techincal prowess, reliability or general 'bang for buck'? With a good review to back it up preferbly.
vpacalypse
149
I want an AV sender which will transmit a HD signal. At the same time I don't want to be spending £250 odd.
Is there anything around the £50 mark?
D3CYPH3R
31
Never tried, but what about HDMI over Ethernet? then use homeplugs to not have to use a long ehternet cable?
daveh75
603
29
18,920
HDMI baluns wont work with homeplugs/on a network, as they dont use TCP/IP
ASK THE COMMUNITY
