- Aug 10, 2019
- 2,556
- 4
- 0
I read the reviews of Denon Receiver AVR 1910 in whathifi.com that said :
Don't go on an Audyssey.
This model uses Audyssey MultEQ to help set up your speakers, which allows the readings to be taken from up to six different seating positions.
We found, however, that the '1910 performed best with the Audyssey system turned off. We'd suggest you perform a manual set-up, or allow Audyssey to measure your speaker distances and levels and then turn the EQ off once the set-up procedure is complete.
Why ? Is the audio sounds unnatural or not real ?
Thank you
Thank you
