audiolab 8200cd usb!!!!
:dance:
Peeps, i have just bought the 8200cd audiolab, running through mission 753f and an old 8000s, and my mac via usb. My
problem is that through the usb i only get 96k is there a way of getting a higher rate??? Also would i get any bennifit from buying
the 8200a amp?....
thank's in advance for any help!!.
littlemong.
rymidd
35
96 k is the highest sample rate setting I run mine audiolab 8200 at 44k as this is the same sample rate for most audio from cd.
upgrade the usb cable to a wireworld cable at around £40 will improve the sound.
ID.
207
I think the max on most USB inputs is 96, and the only ones that let you go higher provide special drivers (software) that you need to install to achieve it. I think the Mac's optical output is also limited to 96 (unless you use some special software like Amarra).
