- Aug 10, 2019
- 2,556
- 4
- 0
I have an Audiolab 800CD which I would like to connect to my Cambridge Audio Azur DAC Magic. The output from the 8000 is via a BNC 75ohm socket and the Cambridge Audio has Toslink optical and SPDIF coaxial inputs.
My idea would be to use a BNC plug to BNC plug 75ohm coax cable which I would connect into a BNC female to RCA male 75ohm adaptor. This would then be plugged into an RCA coax input convertor to optical output. A Toslink optical cable would then connect the the convertor into the Cambridge DAC.
Would this rather complicated setup work for me?
