If you ever spot Spam (either in the forums, or received via forum direct message) please use the Report button at the bottom of each post to make sure a Moderator can handle it quickly. Thanks for your help in keeping things running smoothly!
I'm afraid you are going to get asked for a lot more information before we can supply suitable answers.
Nice amp by the way.
The way i look at things is you do not necessarily need speakers to match an amp, your main concern will be if the speeakers will perform well in your listening room. To that end we would need to know some room dimensions / distance you can have speakers away from the rear wall, whether you prefer stand-mount or floorstanding designs....oh, and also how much you want to spend.
Perhaps the following thread on another forum might be of some help:-
I have a 4 x 5 m room and I have dynaudio dm 2/7 and would recommend an audition. Some might say they are too big for a room my size but I love the depth of bass.I had booming issues when they were new but after a month or two I have zero boom now.I heard the audiolab 8200a with these and they sounded great.I think you can get them at a reduced cost now.
