Audioengine A5+ alternative
Atto
Hi, I feel abit out of my depth in this forum off audiophiles as Im not very knowledgable but i love music and am keen to learn. My first post is to ask advice about some speakers im considering buying. audioengine A5+. my needs are
- stereo speakers.
- that I will run on bluetooth from a mac.
- i have no amp so 'active' seemed a simple answer though if active compromise greatly on power and quality for the convenience I'd go for and bluetooth amp and speaker combo for about the same price.
- i will use the speakers for 90% music (then the odd film on low so extreme base wouldn't be an issue and I'm not fussed about cinema suround etc).
- I like power ,clear punchy base, sharp treble and clarity.
Is what im looking at a good idea? if not some advice of other active speakers or a blue tooth amp and speaker combo for around £350 would be massively valued. Many thanks for any help.
domenn
42
Hi Atto have a look at Q acoustics BT3 , these should tick your boxes
greetings
davedotco
- stereo speakers.
Hi Atto.
Given that Bluetooth is not that well implemented on a Mac, I have to ask why you are not using Airplay or even a wired usb connection.
A little more detail on the way you want to run the system would not go amiss.
