Audio Physic Classic On Wall
El Hefe
260
17
18,895
Hi all,
Anyone have experience with this speaker? I am installing a motorized projector screen and planning to have these speakers mounted on the wall BEHIND the screen. I dont have space to put a floorstander in fornt ot the screen.
Will run it with a Yamaha RXV2067 AV amp.
How is the performance of this speaker with regards to playing movies? Dont really care for musc reproduction..... just for movies.
Thanks.
Thanks bigboss.
Yes they are primarily hifi speaker company. Quite impressive they are in that department. Hence, thats one of the reason I was thinking of this speakers for my AV set up.
Maybe I can put it in another way...
I just came back from a discussion with the screen installer. Placing the speakers behind the screen is no longer an option as I am not getting a perforated screen.
I basically only have 860 mm in height to place the speakers below the bottom of the screen.
If its not these speakers, any other recommendation?
What about in-wall speakers just underneath the screen?
I'm in a similar dilemma as yours. My projector screen would be in front of the fireplace, so no space for the centre channel. I'm thinking of having some motorized in-ceiling speakers:
