ATC SCM7 - can I drive them?
ekkn
I am considering buying a used set of ATC SCM7 but I keep reading articles that say they are difficult to drive.
I have a Primare A20 mk2, can it handle them?
Best Regards
Erik
ekkn said:
Best Regards
Erik
Hi Erik
Yes, the Primare will be able to drive SCM7 monitors perfectly well. Put it this way if a NAD C325BEE can drive SCM7 monitors then with it higher quality of amplification the A20 MK2 will in comparison take SCM7 monitors in its stride
All the best
Rick @ Musicraft
