- Aug 10, 2019
- 2,556
- 5
- 0
Hi
I've recently bought a Yamaha AS500 amp, and I've noticed it makes quite a distinct clicking sound a couple of seconds after the power is switched on. It only happens once after each time the power is switched on, and it doesn't seem to be causing a problem at the moment, but I'm wondering if it's something that might become an issue later. Does anyone know if this is normal, or is it some kind of fault?
Thanks for any advice you might be able to give
