Really? I think it's very stylish, and unmistakably Audiolab, looks a lot like the classic 8000A.described as very unstylish by one reviewer.
Yep same. Doesn't sound too bad to me but I actually dread running REW - I actually bought the mic a few months ago and haven't done it yet. Big part of it is getting to grips with the software but I suspect there might be a little concern that it'll show all sorts of issues I won't be able to fixI sadly don't have space for a dedicated room. Mine is in the living room. Room dimensions and acoustics actually aren't too bad!
Really good looking set up by the way.I sadly don't have space for a dedicated room. Mine is in the living room. Room dimensions and acoustics actually aren't too bad!
Getting my speakers in the right position made a world of difference to me. First reflection points aren't bad. Bass traps may be a benafit, but I don't really have room.Yep same. Doesn't sound too bad to me but I actually dread running REW - I actually bought the mic a few months ago and haven't done it yet. Big part of it is getting to grips with the software but I suspect there might be a little concern that it'll show all sorts of issues I won't be able to fix
"dear wife, do you mind me putting 2 monster bass traps in the corners? Yes one would be right in front of the kitchen door. Great and and a couple of panels on the ceiling as well"
She's very patient but I suspect that might be a touch too far 😂
I don't have a dedicated listening room either. AV in front room little Denon system in dining room. If my adult offspring had left home the cellar might be a listening room but then I think would the low ceiling be detrimental to the sound. Currently the cellar is their room, two gaming PC's one hooked up to a pioneer AV receiver with TDL speakers for the front some tibo speakers for the surround. There are two leather sofas down there, a little LG projector and a 60" screen they pull down in front of the monitor when not gaming.I sadly don't have space for a dedicated room. Mine is in the living room. Room dimensions and acoustics actually aren't too bad!
I've been thinking about this a little more and am actually really enjoying listening to my main system in its compromised position. I think a combination of the fact it actually sounds quite good and the "treat factor" that it gets switched on and listened to for an hour or two once the two-foot hifi destroyer has gone to bed. But you can't measure that I guess?Currently satisfied as all listening positions are compromised. Will make some tweaks in due course ... but nothing major until a dedicated listening space can be obtained.
Thanks. I have had a bit of a shuffle around since the picture was taken. The sub for the AV system is properly positioned and the amp in the stereo has more room around it to help cooling.Really good looking set up by the way.
Same - plus my speakers don't go particularly low and, although I am far from a bass-head, I have been feeling that LF is something I might want more of, not less. I suspect traps might help clean it up but possibly also attenuate it. With speakers position, i am sadly a little limited as they are along the narrow side, so there's only so much I can do. Although, following from above, I started putting them pretty much against the back wall to get some extra help with LF (as they are front ported ayway) and it has made a difference...Getting my speakers in the right position made a world of difference to me. First reflection points aren't bad. Bass traps may be a benafit, but I don't really have room.
