Are these a bargain?
tommyb
87
I inserted these in another post, but they probably shouldn't have been in there. Are the two cables below a bargain or are they not as good as they appear?
They look like bargains to me. I'm currently using two run of the mill composite video cables for the purposes:
Sub Lead: http://www.chaseavdirect.co.uk/ccp6/prod--Profigold-PGA4120-High-Def-Subwoofer-Interconnect-2m.html
Digital Coax Lead: http://www.chaseavdirect.co.uk/ccp6/prod--Profigold-PGD4000-High-Def-Digital-Coax-Interconnect-0-75m.html
All opinions welcome.
I'm not looking to spend much more on the cables to be honest. i.e. £50 for a QED sub lead in my opinion is overly priced.
I'll be hooking up to an Onkyo 875, Quad l-ite 5.1 speaker set, and a 'normal' dvd player.
Hi i agree with you about £50 being a bit rich for a sub lead however they can be found cheaper, personally I would be still looking at the QED range of cables a quick look on hificables.co.uk shows a coax for slightly less and the sub lead about 27 for a 3 metre and you'll get free delivery aswell.
try ixos xhd 608 for a coaxial lead was whf best digital connect got mine for around 35 notes down from 50, with a bit of looking im sure you could get the same deal oh and delivery was included
