pix:
Hi I've just bought a solo mini and am very pleased with the sound quality. It is very clear and detailed. I think it is what people who know about such things call an 'open' sound. 'Confident' is a word that comes to mind when I listen to it. I auditioned it with the denon dm37 and the cambridge audio 1, and the sound quality was so much better that I had no trouble making my decision, even with the extra money the solo mini cost. Having played with it I discovered a software bug on the cd shuffle mode. It never plays the whole cd, only the ones it likes. I contacted Arcam and they said they knew about it and were currently developing the software to correct the fault. All the units already made will need to be updated with the software on a pen drive. It's a minor thing if you choose to have the rdock that goes with the unit. Then you can shuffle to your heart's content. The sound quality is v good on the rdock, although i found I had to turn the sound up a little bit, especially on purchased tracks. Purchased tracks burned on a cd don't need the volume turned up at all. My rdock developed a fault after the first day. The yellow light on the adapter started flashing, and the blue light on the rdock started flashing. When I tried to play a track on the ipod, the rdock ignored me. It just put random things onto the arcam display that bore no relation to what I was selecting with the remote. I think I am rather unlucky! Up to then I was v pleased with it. I think it was a customer return as the box and manual inside were well bashed about. If you buy the rdock you'll have to buy interconnects separately (another £30). You'll also need the piece of plastic that came with your ipod to fit in the rdock.
The remote on the solo mini is quite well designed but the way they've labelled some of the buttons is a little strange. They've labelled the ipod button 'tape'. I think people are more likely to have an ipod that a tape player these days. Also, I wish they'd made the fm button the am button too. Instead the DAB button is also the AM button. This is less logical and a little annoying when you choose DAB from standby and get AM, because by pressing DAB on standby you actually toggle to AM. If you buy it and use DAB you'll understand!
In spite of all the little niggles, I'm still glad I bought my mini, simply because of the sound quality, which is important to me. It is also very lovely to look at . I expect you might be able to get better separates for the price, but it's the size of a biscuit tin so if you live in a small space like me it's ideal.
I may have asked you this before, I also have the Mini, which speakers are you using?
