i have a bose wave system is it possible to connect the rdock via aux. If so r the cables supplied with the rdock worth keeping if not what r the best cable for it? thank you for yr time
If the Bose Wave system has a standard set of phono in sockets then yes, you should be able to connect the r-Dock OK. The cables supplied with the r-Dock should be fine.
