Arcam power amp
Hi there I will try explaining this properly, forgive me if I confuse anyone.
If I use an arcam A65+ and an arcam power amp do I have to run two sets of speaker cable ( ie bi-amp ) or can I just have one set of speaker cables from the power amp and an interconnect from the pre-outs on the 65. Will this give me a pre amp power amp situation
or do you really have to bi-amp to get that result. If my way is feasible will there be any sound improvement.
By the way what would be the best interconnect to use I have B&W 600 speakers.
Hopeflly that makes sense
Cheers RS
No you can as described run the 65 as a pre amp and the power as the power amp - so just connect speakers to the power amp
But could also bi amp using the 65 for the hf and the other amp for the low frequencies
i would try both and see which you prefer
