- Mar 20, 2014
- 11
- 0
- 0
I am listening to the bulk of music now via the pc into a irdac , whilst the sound is good, there are often clicks, as though there is a fraction of a second break, its not every listen time , but once it starts its quite regular, the same click happens when I skip tracks, but when it happens mid way through a piece of music it sounds like when you get a brief click like with fm radio,
could this be the pc , I am using the usb 1 setting on the dac, should I be using the 2 setting , but the sound goes off when I do this, should I be using specific usb 2 drivers? the issue was far less a problem with my old dacmagic, i thought this was supposed to be a super douper usb dac which locks onto the signal better seem not
