Arcam DV137 vs DV139 - Audio playback
Overdose
279
The title really says it all...
For purely audio purposes and price aside, what are the main differences/improvements, if any, of the DV139 over the DV137?
One of these might be my solution to less boxes on display.
CnoEvil
556
14
I will do my best with this one.
As you know, the DV139 was the pinacle of Arcam's DVD line. It commanded a £550 premium over the DV137, due to some tasty extras such as Wolfson WM8740 24/192 dacs and two power supplies, to get the best out of both audio and video.
It also played full SACD in 5 channels.
The DV137, "audio-wise", was no great improvement over the previous DV79.
SACD is also only presented in stereo.
The DV137 is very good for audio, and one of the best in its price bracket but the DV139 is simply better in every way, and one of the best out there (for a DVD player).
It was worth the difference then, so if you can find it at reasonable money, it may make sense.
I only wish their new blu-ray worked as well, and was as high a quality - promising as it may be.
Overdose
279
That's brilliant thank you.
Dazmb
57
As a 'one-box' man myself I too choose the DV139 as said one and only source box. And I can confirm that it is VERY good with audio duties from it's analogue output. It doesn't do native DSD for SACD, it converts to PCM - but Floyd's DSOTM SACD still sounds pretty fab too me when played.
Go for it ;) , but keep an eye out for the typical Arcam firmware gripes. The last stable firmware revision is 4.12. The last firmware 5.02 has bugs with HDMI handshake. I know as it won't hook up a signal to my 2008 Panny plasma tv.
