dantan:
This is looking like it is going to be a highly-competitive unit. Arcam does make good stuff, and I believe its 7 x 120-watt figure is a lot 'truer' than a lot of 7 x 200-watt figures. It will likely be more powerful than most A/V Receivers, which make extremely bold claims that are really figures when only one or two channels are powered by the unit - and NOT for the entire audible range of 20hz to 20khz.
However, in Australia, I am expecting it to cost quite well over $5,000.00 (early suggestion seems to say $5,699.00 in Australia), which is a lot of money.
The way I look at it is, I would rather spend this kind of money on a separate A/V Surround Processor and Power Amplifier. My reasoning is that a good Power Amplifier will last you many years. If you were to put in a lot of money on an A/V Receiver, if other formats or other types of connections are released next year or the year after, etc, you might look towards replacing the unit, which you spent heaps of money on!
If you went the separate Pre/Power combo, you could replace the Processor if new features are released that you feel impelled to have, and keep the wonderful Power Amplifier that you have.
If you were to go the A/V Receiver route (a good A/V Receiver, such as this Arcam, which I am sure is a wonderful unit) and are happy with the sound quality, etc, if you were to purchase a new one down the track (which might end up being a different brand with different sonic qualities, etc), the sound quality will be different, and it may be a little 'luck' as to whether you prefer the different sonic signature/quality.
Just my two bob's worth, mate.
Thats actually spot on thinking - I hadn't considered that angle but it makes total sense now you mention it particularly given my current upgrade situation on an amp that I've had for less than two years - granted it was almost due to be replaced when I bought it but still.
The Rotel kit does indeed look impressive - I was watching a vid on it the other day as it happens. Any ideas how Rotel or NAD fit with Monitor Audio gear? Also, any time and cost expectance on Aussie availability of the NAD processor you're waiting on - I'm keen to check that out too. Luckily I have kit that works and thus time is on my side with the upgrade.
