Arcam AVR350 Problem
da_grudge
76
I just bought this receiver. My problem is that I can't get into the menus for the config. I have it connected with hdmi to my Pioneer tv.
It seems I need to connect with component cables to get the menu, at least is what I understand through the manual.
Is this correct? Can someone help me?
To quote from the manual:
"The best way to set up the AVR350 is using the on-screen display (OSD). To view the OSD for the initial set up, use the composite video output to connect to your TV. This is because the high quality video output has several display modes and may be incompatible with your high quality display device in its default configuration. Note that no on-screen display is available over the HDMI connection. "
You can't use HDMI, I'm afraid.
ASK THE COMMUNITY
