Arcam A18/CD17 Break-In Time
Happy_Listner
23
I just bought an Arcam A18 integrated amp and Arcam CD17 player. It's sounding a bit bright , thin and ragged right now. Sounded smoother and fuller at the store. How long does break-in time last? I only have about 8 hours on it so far.
Or perhaps I should change my speakers and wires? Maybe they are not a good match? I have Proac Signature 2000 speakers, Cardas 5-C quadlink interconnects and Audioquest Type 4 speaker cables.
Thanks in advance.
matthewpiano
My advice would be to try stripping your cabling back to basics. Try some good quality multi-strand copper speaker cables and some OFC interconnects such as the Van Damme ones. I suspect this might take you closer to the sound you are looking for without the expense of changing your speakers. If you ever do decide to change your speakers, do audition the PMC DB1i. When I had the A18/CD17 combination I did just that and the PMCs sounded stunning with the Arcams. Trouble was, in the end I could not afford the speakers and I couldn't achieve the results I wanted with cheaper ones so I sold up and moved in a different direction.
Let us know how you get on if you try some more basic cables. Also pay attention to speaker positioning and experiment a bit. I did just that with my own system recently and, to my surprise, found that moving my speakers quite subtly had a big impact on the overall sound.
MeanandGreen
149
69
18,670
Thanks in advance.
I would give it another 8 hours, if by then it's no better then I doubt it's going to change anymore. Speaker positioning may help,after that you could try cables but you shouldn't need to spend even more money if you have good cabling to begin with.
Agree with Matthew - first look at cables. The SilverScreen work very well with Arcams.
Should you decide to change speakers hears a nother vote for PMC DB1i. They are truly a cracking monitor. Alternatively Focal range work amazingly with the brand too.
Happy_Listner
23
Thanks to everyone who wrote in so far. I read somewhere that it can take up to 100 hours for a new component to fully break in? I can't imagine myself that the sound will change that much anymore. I played it for 3 hours the first day and about 9 hours yesterday. I'll give it a further good run in this weekend.
I'm getting a sharp sound with sibilance, the T and S sounds with voices are very shrill. Somwhere in the upper midrange and lower treble region is the part that is bothering me. I guess I can be pretty sensitive to this. A componet needs to be smooth in this area for me.
I owned a used Arcam Diva A70 for a very short time about a year ago and I don't remember it being as bright as the A18 is. I paired it with my Proac's and the sound was smooth with very few traces of harsh sibilance.
The one varible that I also changed in my system is my CD player. I still have my old one and haven't sold it yet. It is a Cambridge Audio 840c. I think the C.A. might be a bit better player than the Arcam is? Not sure. I got the Arcam CD17 because I wanted it to match the Arcam A18 and I heard that it's good. But maybe the CD17 is the culprit? I'll have to get the 840c back out of its box and make a comparison.
The cables I'm using are known for being smooth and for taking off any slight edge in the sound. That's why I'm using them. Perhaps I can still try some other brands and types. I never heard the PMC's in person before. That might be somehting to look into as well. My Proac's are getting on in age, 12 years old now.
One other note, my last amplifier was a Creek 4330. It broke down on me a few weeks ago so that's why I bought the Arcam duo. Now that is a great amp! Smooth and sounds powerful. They don't really make them like that anymore. Passive pre amp and mosfet output stage. Never had any brightness problem with it. The Arcam does beat it in detail retrival though and with smooth recordings can sound quite magical.
k77stan
24
6
18,525
Thanks in advance.
i recently bought a new amp and straight out of the box sounded nothing like what i've expected-thin and not much bass,i thought i made a mistake..however a few days later,some 15-20 hours of listening there was a favourable change of sound and much better than in the beginning,same with my speakers...so i for one do beleive that equipment does need some time to settle in just like new shoes ;)
matthewpiano
Having owned both the A18 and the Creek 4330R, I'd personally say the Creek is the better amp and I think another Creek would have made a better replacement - something like an Evolution 2.
It would be worth trying your Cambridge 840C CD player as I suspect it might help to resolve your issues to some extent, good though the CD17 is. You've got nothing to lose so give it a go!
Happy_Listner
23
I'll hook up the Cambridge Audio 840C tomorrow. I thought about getting another Creek but I didn't bother to look at them because the design of most of their models has changed since my 4330. The new Evolution uses an active pre stage and a bi polar output stage. Only the Creek Destiny 2 uses the same old formula, Mosfet output stage and choice of active gain pre amp stage or pure passive. Very nice. Would have bought that one but I can't afford it.
MeanandGreen
149
69
18,670
Me too, my new NAD sounded nothing like it should from the box. It only took around 10 hours to loose the shrill upper mid and lower treble. The bass gained a lot of wheight too. I Don't think it should take more than a handful of decent listening sessions to settle in. I would say if after a week of using for a about 3 hours a day that should be pretty well ran in and sounding how it should.
CnoEvil
556
14
This is indeed a little strange, as in theory, it should sound smooth.
- I would put the CDP on repeat and let the system run, if possible for a few days....just to rule out "break-in".
- I don't think this is likely to be a cable problem.
- If you have heard the speakers sounding well, then they are not the problem.
- Is there anything about the room that could be making things worse (laminate floors, large areas of glass or tiles etc)?
- If the CA CDP sorts out the problem, then that is great, but I would be surprised if it did.
- It's possible that the combination of the A18 and the Proacs are highlighting worse recordings.
At a guess, the problem could be synergy between amp and speakers, mixed with possible room acoustics.
Trial and error will be the key.
Happy_Listner
23
Hello Everyone,
Well I had an interesting few days breaking in the Arcam units and comparing and contrasting. First of all I have to say that the Arcam A18 and CD 17 both sound a bit better than they did before. Played them all weekend and on Monday. The sound has smoothed out some but not 100% to where I would like it. But the sound has opened up more and they now sound more dynamic. Bass is better and the treble slightly smoother. I think I have become more used to the sound. The clarity is quite amazing that these two budget components offer. The sound can be very beautiful at times and I can hear every detail in each recording. Some recordings I hear detail I never noticed before. The Arcam duo does have a slightly soft and laid back sound. Still a bit too bright though in the upper midrange and treble. I notice this area more than most people. Not bothersome on any music but only sometimes on some recorded voices. The S and T sounds sounding a bit too sharp and artificial. Overall though the sound has grown on me. I suppose I can't really ask for more at the price.
I hooked up the Cabridge Audio 850c to compare to the CD17. Yes, the C.A. does sound a bit smoother and the soundstage is perhpas a bit wider. Yet, the clarity of the Arcam still won out. I can hear more detail through the Arcam. With C.A. most of the detail is there but I feel like it's smoothed out too much and too processed even. The Arcam Cd17 is a bit brighter, maybe a bit rougher, but also it is a more interesting listen. Some could easly say the C.A. is the better player, however I have more fun listening through the Arcam.
I am impressed with this duo. It's not perfect, but then nothing is at this price. I guess there is some truth to this break in time after all. The sound did change, but not dramatically. I'll let you all know if the sound changes any more.
ID.
207
Interesting because, going by reputation, the CA should be brighter.
Sibilance isn't much fun to listen to, although listening to live performances I'm often taken by just how strong plosives, s and t can actually sound. Similarly, brass (particularly trumpet) and strings (like violins) can also have a suprising amount of bight when heard in the flesh. Not everyone actually wants to hear that, or hear it emphasized, when listening at home.
drummerman
540
Yes, I am fairly sensitive about sibilance too.
Arcams, as far as I know, usually measure well so its unlikely to be distortion unless you are listening at higher volumes and drive the amp into clipping on peaks. The OP's previous creek has perhaps been unusually rolled off or/and may have had some component deteriation, which can happen over the years.
regards
Happy_Listner
23
That is true ID. Concerts in person can sound bright too. But perhaps it's the more focused sound from the speakers that can emphasize this more? In a concert it is there also but we are sitting in a large hall where the sounds are more diffuse. Just a theory...
You are right about Cambridge Audio in general sounding bright. However, the 850c CD player was somehting quite special and sounded a bit different from the rest of thier range. It has gotten praise from all the mags, most saying that it sounds smooth, and to my ears it does. Now the newer C.A. 851c is entirely different sounding. Compared to the 850c it is more forceful and bright sounding from some of the reviews I have read so far.
ID. curious, what components are you using in your audio system? How do you like it?
Happy_Listner
23
drummerman,
I usually don't listen to the Arcam past level 40 on its electronic indicator. It is a medium loud range. Never listen too loudly and my Proacs are 87db 8ohm speakers, not too hard to drive. So I am fairly certain that I never clip the Arcam.
The Creek 4330 was old for sure. The voume pot gave out. I think the Creek sounded smoother than the Arcam for two reasons; 1. A lot of audio sounded smoother 15-20 years ago. These days I feel like all the manufactures are going for more resolution and brighter sounds. 2. The Creek uses a passive preamp section along with mosfet output devices. The Arcam uses an active preamp and Sanken bipolar output devices. From personal experience whenever I have listened to a mosfet amp it has had a slightly warm and more rounded sound to it. I have also heard a few other passive preamp integrated amps before such as the Acurus DIA-100 and also a McCormack passive preamp with power amp. The passive preamps seem to give good resoulution but can also sound a little on soft side.
My favorite integrated amps have been the Audio Innovations Alto and Creek 4330. The brightest sounding integrated I have ever tried at home was an Audiolab 8000s. Wow was that bright! Almost tore my ears clean off.
This Arcam A18 is pretty darn good. It is musical and has clarity. I guess I'll just have to put up with some occasional brightness with singers. I guess not too bad for the price point.
CnoEvil
556
14
I would agree with this.....especially if you were brought up on a diet of vinyl as well.
My preference resides in the now "out-of-date" and environmentally unfriendly tech, such as Valves and Class A...........I can see them being outlawed in the not too distant future. :(
Agreeing with Cno's sentiments I think that speakers from professional stables have some blame here. Proac and PMC come to mind, though I have heard great music from both brands.
Mine were influenced allegedly by their designer's love of the gutless LS35/a so could never be found overly bright. I'd rather hear most things at their best rather than ruthlessly analysed.
As for the OP, I would give it plenty of time on running in and adjusting to a different presentation. It's not just tonal balance either.
drummerman
540
Happy_Listner said:
drummerman,
We seem to have similar taste (dislikes). I too had an 8000S years ago and didn't like it. It was gone within 3 months. Oddly enough, I also had an Audio Innovation though it was one of their integrated valve amplifiers, this one I liked very much.
I am unfortunately not familiar with Arcams electronic volume read-outs but it is possible that if you use 'medium loud', the amplifier clips with peaks. - If sibilance is an issue at low volume too, this however is unlikely to be the cause. It could be though that either your cd player or amplifier has left the factory slightly mis-aligned/under-biased. I have not noticed sibilance to be a particular problem with them, I would have remembered that. It may just be worth it to compare them to another set.
Rega used to have a similar, slightly laid back nature with perhaps less forwardness higher up, all else failing but as you already have noticed, you seem to get more used to the Arcam's and may well find that switching to another brand is a one step back.
I dont agree that the use of an active pre-amplifier stage has to mean bright or harsh. There are plenty examples out there otherwise but fets have traditionally have had the reputation of being more valve like but have their own problems with correct implementation.
regards
Native_bon
181
+1
I know for sure hifi these days tend to go more for resolution & in the process tend to sound more bright ... Am one of those who is very sensititive to the S & T sounds... Most amps these days seem to do just that..
Yes do agree with Cno valves or class A amps may be the way... This seems to be the norm every time someone buys a new system.. Reports on this forum of thin & bright & lack of bass. I think over the years people have gotten use to this type of sound now its becoming the norm..
Happy_Listner
23
Just wanted to give everyone an update. Ran the Arcam duo in a lot during the past week and just can't shake thier brightness. Sounds good with only music playing, but with voices on about half the CD's I play there was just too much artifical brightness, sharpness, edge, sibilance, mechanical, or however you want to describe it sort of sound to it.
I played the New Order "Get Ready" CD and had to turn it off. Everytime Bernard Sumner started singing on "Crystal" the T and S sounds were unberable. It is ridiiculous. Are people deaf? Are all the audio designers getting old and going deaf? Do I have super human hearing? How do most people put up with this crap these days? They used to make audio components that were at least listenable a decade or two ago or more. Now its all about resolution, clarity and brightness. I don't care about hearing every detail I'd just want something pleasent to listen to.
I talked to my dealer and he is more than kind enough to take back the Arcam A18 and CD17. On another note I was able to get my Creek fixed for about 75 pounds. Looking forward to putting in back into my system. Never had a problem with sibliance with the Creek and the Cambridge Audio CD playing music.
So I start at square one. My Creek 4330 can't last forever. Any suggestions you might have on an amp I'd be happy to hear. Anyone listen to the Croft phono integrated? Look interesting. Like my Creek it's a mosfet and passive preamp design. Has the added bonus of having dual volume controls, point to point wiring, and uses a tube in the amp stage and 2 tubes for the phono stage. On paper at least it seems like it should sound smooth and slightly warm.
CnoEvil
556
14
You are a definite candidate for Class A / Valves / Hybrids.
Your search in the future should be looking at the likes of Sugden, Pathos, Icon Audion and Unison Research.
T
the record spot
Thanks in advance.
Keep it simple. Your AQ Type IV will be fine, no need to go mad on this and they're good ones, leave the interconnects as is. I have a set which I used for the best part of ten years. Try also repositioning your speakers slightly, toe them a little further out, or in, or shift them around a bit, not much, six inches to the left or right can make a huge difference. More, in fact, than any cable will ever do for you.
I tried the a18 in my system not too long ago. It was brighter in the treble but, crucially for these ears, smoother in the midrange-upper mids in comparision to my Marantz PM8004. I quite liked the sound of the a18 overall, except I felt that it really lacked dynamics. Having recently picked up a primluna prologue one -- a real smoothie this one -- I suggest you follow the advice of others and try class A or valves, especially with those proacs, which everyone seems to pair with valves likely to tame some of their less than well mannered behavior. That or try different speakers.
