ARC control question
Hi guys,
Just a quick question. I currently have a Panasonic EX98V running to Yamaha 671 AV amp then to a Toshiba HD ready tv (non ARC). If I buy a Panasonic BDT310 3D blu ray player and a Panasonic 3D ARC compliant tv, can I run the blu ray player straight to the tv and the HDMI cable, which is also ARC compliant, will sort out the sound to the AV amp or am I missing something? I still want to keep the EX98V hooked up for recording.
Many thanks.
SD1.
The_Lhc
1,176
It's unlikely you'll get full HD audio from blu-ray doing it that way (or it might not be, I've no idea). Is there anything stopping you from connecting the blu-ray player to the amp in the usual fashion?
I thought I would have done due to the HDMI leads being HD audio compliant. Technically there isn't anything stopping me but the four assigned buttons are already assigned. A bit petty I know but just trying to make things easier.
The_Lhc
1,176
Trouble is the tv may inform the bdp that it can't handle HD audio so the bdp won't provide it. Regardless of of how the inputs are assigned it will be much easier if everything is plugged into the amp.
Ah I see! To be honest, I wasn't really fussed about the HD audio, just after a digital connection but will see what I can sort out. Many thanks for your help!
