Im running my apple tv into a rega brio and set of in wall focals. is there any point on adding a dac from apple tv into my rega direct. will it make a difference
Mike_Schmidt said:Im running my apple tv into a rega brio and set of in wall focals. is there any point on adding a dac from apple tv into my rega direct. will it make a difference
Juzzie Wuzzie said:You'll need a DAC in any event, won't you, as the ATV only has digital out, and the Brio analogue in? At one time I used a CYP £25 DAC (AU3) and the worked a treat.
