App Updates.
mattytun1514
67
Everyday i click "play shop>my Apps" just to see if my Apps are upto date,Well tonight i got a update from Avast so downloaded update then after it downloaded i got about 15 other app updates do you think avast was blocking some updates.
I wouldn't have thought so. Maybe you just started a wifi session? You don't need to check every day really. Most apps have an auto update check box.
Hi yes i was on wi-fi..cheers
