A admin_exported New member Aug 10, 2019 2,556 5 0 Jul 5, 2009 #1 The Sync to i pod isn't highlighted , when I ripped C.D's so I can't put them on i pod? Thanks.
idc Well-known member Jan 2, 2008 1,172 147 19,370 Jul 6, 2009 #2 If you are having problems synching your ipod you can; -try another cable. I have found that that the cable is often the cause of the PC not recognising the ipod when you connect it. -try another usb port, synching works better with usb 2 - check out your ipod with the 5 Rs http://www.apple.com/support/ipod/five_rs/classic/
