Any speaker suggestions?
I listened to Kef Q700 and 900. Really loved the clear and open soundstaging and the wide dispersion area, but was a little disapointed with the bass. This was with a Uniti and NAP 200 amp. The 900's were a little improvement on the 700. I want What could I try next? They would have to match the Q's open, 3D qualities.
Singslinger
16
Is it floorstanders or bookshelf speakers you're after? And what about your budget? I've not much experience with the floorstanders and the Uniti except for the ProAc D18, a combo I liked but I'm not sure if this falls within your budget. I use the Uniti with a pair of Elac BS244 speakers and occasionally with the PMC DB1i. The Elacs have a ribbon tweeter so trebles are very sharp and defined; the PMC's main strength is the very pleasing bass it produces for such a small cabinet. Hope this helps.
