ANOTHER MAINS QUESTION
I want to upgrade my mains cable to my marantz 7003 CD player but looking at the socket in the back of the unit it only has 2 pins were as all the leads i've looked up have 3. Its the same shape, rectangular with the top corners chamfered but only 2 pins. Any ideas ? Also whilst I'm here mains conditioners is there one similar in value to the Tacima but only with 2 sockets, the six socket unit would be to big for were its needed.
Andy looking at the figure 8 leads they don't look suitable. Hopefully you can see on the picture below
idc
J.B, with regards to your second question re a two socket mains conditioner, the minimum seems to be 4. I have two, Russ Andrews 2 way sockets (which do not appear to be available any more), but the problem is that the sockets face each other, rather than being in line, so they limit what you can plug into them. Only standard plugs will fit. So four appears to the best compromise.
Thanks for your responce. I think i'll look at the QED 2 way conditioner.
