An opportunity to upgrade
Covenanter
87
32
18,570
With Stock Markets doing so well I'm pleased to say my pension fund is booming so I can think about a major upgrade to my system - Marantz PM6004/CD6004 with Kef Q500s. Now I actually love the system so it would have to be a big step up and as I think what I have is well balanced I think I'd have to replace everything. Here are the criteria:
- Mainly classical from early polyphony through to 20th century
- Lots of solo voice and solo instrument so clarity is of paramount importance
- I like what I think of as an analytical sound, every instrument clearly identified and placed
- Live in an apartment so most listening is at relatively low levels, certainly don't need anything that would shake the windows!
- I'm not into streaming or vinyl so the source will be a CD player
- Budget £3500
Chris
tomlinscote
30
"I like what I think of as an analytical sound, every instrument clearly identified and placed"
maybe Cyrus kit then, you should be able to get a decent 8 based system for your budget, no idea what speakers suit cyrus stuff but someone will know.....
Tommo
gregvet
128
10
18,595
I would second the cyrus option, based on what you have said you like.
A cyrus transport, the CDT for £650 new for eg, plus a second hand Dac XP+ (available for less than £1000 relatively commonly from eBay or the cyrus unofficial forum), and either a second hand x power or pair of mono x's (at £500 or £1000 respectively).
For speakers you would be strongly advised to at least hear the Kef LS50's, as they are very detailed without being bright or tiring, and so may give you exactly what you need. However, if you need more/deeper bass then the R500's may be more to your liking.
Depending on which options you went for, this would come to between £2850 and £4150 at the book prices, not including any discounts you haggle :)
Edit: your CD player has optical out, so can be used as transport only. Save some money initially and only get the cyrus transport if you can't cope without all the boxes looking similar :)
This would bring the overall cost down to between £2250 and £3500 depending on which power amp and speakers you went with.
Phileas
- Budget £3500
Chris
Apologies in advance but your requirements suggest you're an ideal candidate for AVI ADM40s.
pauln
137
- Budget £3500
Chris
Seems to me that Harbeths, with whatever source and amp takes your fancy, would be perfect. I'd suggest you take a look on the Harbeth User Group forum.
altruistic.lemon
64
Magnepan or Martin Logan for me. Both are brilliant with classical, and, in fact, that's why I bought mine. I use a 70W amp with mine, but Ashley of AVI on another forum suggested something more powerful would be far better, so I'd probably suggest the M3i (130 watts into 4 ohm) from Musical Fidelity, one of the Quad amps, the HK 990 or the NAD375.
CnoEvil
556
14
As a lover of classical music, you might like to consider the following:
AMPS
- Sugden A21
- Pathos Classic 1 Mk 111
- Electrcompaniet ECI-3
SPEAKERS
- Harbeth
- Spendor
- Kef R Series (possibly LS50)
- Proac
Electro
192
I would add PMC twenty 21 or 22 speakers to CNO's excellent list of speakers and amplifiers , I think they would suit your list of requirements very well :)
DocG
54
What is your room like, Chris?
Personally, I love panel speakers (and Magnepans in particular), and I understand very well why AL estimates them so highly for classical music. But they need space, say one metre behind them - you can place them relatively close to the side walls though.
Besides space, Maggies also need current (lots of it!). The Pathos Classic CNo mentioned, maybe?
DocG
54
Covenanter said:
I couldn't have speakers 1m from the walls I'm afraid.
Chris
Then my vote goes to Harbeth. And if you ever have the opportunity to hear Magnepans: don't do it (ignorance is bliss :)).
On a different note: I would spend the money on speakers and amp, and keep the CDP; upgrading your source would probably have least effect on the overall sound.
Covenanter
87
32
18,570
Many thanks for all the suggestions. I live in Birmingham, the UK's second largest city, and this is the result of my first trawl looking for dealers of the kit you variously recommend:
Arcam – Ok
Sugden – No dealers in West Midlands
Creek – Ok
Cyrus – Ok
Electrcompaniet – No dealers in West Midlands
Harbeth – No dealers in West Midlands
Kef - Ok
Musical Fidelity – Ok
Naim – Ok
Pathos – No dealers in West Midlands
ProAc – Ok
Quad – Ok
Spendor – No dealers in Birmingham
I fear this is going to be a frustrating exercise!
Chris
BigH
115
7
18,595
Arcam – Ok
Creek – Ok
Cyrus – Ok
Kef - Ok
Naim – Ok
ProAc – Ok
Quad – Ok
Chris
Looks like you may have to go to Coventry, haha. At least you have most nearby.
I think the nearest Sugden is Huntingdon.
As you are in Birmingham you could pop into Fiveways and hear some AVI 9RSs.
Macspur
843
Chris,
If you do fancy giving Sugden and Harbeth a go, drop Patrick at Sugden and Alan Shaw from Harbeth an Email. Both will gladly sort something out for you.
Mac
CnoEvil
556
14
Macspur said:
Chris,
Mac
IMO. It will be well worth the effort.
Phileas
Craig M. said:
With that budget this is an easy one. ADM40.
My thought exactly. It would be a shame not to hear a pair before making a final decision, but the next best thing would be to listen to ADM9RSs to get a sense of what they're about.
As a classical music enthusiast myself, I particularly recommend them to Covenanter.
