If you know your SME arms then you know the 3009 had a knife bearing for the horizontal bearing, while it's a good arm that knife bearing has stiction issues. A good arm will use high-quality bearings for all movements, the better the quality the higher the cost but the better tracking of the grove means better detail from the grove. So I have a Thorens TD 160 MKII with the SME 3009 arm that I have owned since new, 1980 to be specific, it spent 5 years in storage and it's had a lot of upgrades done, the arm has litz wire and the connections for the RCA have been changed, I have also been using PTFE lube on the knife edge bearing that has improved the arms horizontal tracking as heard when using my Ortofon test record, but I keep asking myself, should I upgrade to a RB330 arm, I said I would do this a couple of years back but never did as nobody would lend you an arm to try unlike say an amp or speakers, So the question is, will the RB330 be better or as an example would I need to spend £2000,00 as that's what a new SME 3009 would cost if you could get one, and it has normal bearings for the horizontal movement but otherwise looks identical to my 1980s 3009.
Back in the day, the Linn Sondek LP12 had the same type of deck construction, it was only the Ittok arm that was of much better quality.
