To the OP.
When you say you want Spotify, do you mean Spotify Connect, or do you have it available from another source such as a computer or iThing.
To Drummerman and Vlad.
Regarding volume, sound level and perceived loudness.
To increase the measured SPL of a hi-fi system by 3dB requires a doubling of the power, both the acoustic power emanating from the speakers and the electrical power being fed to them. To double the SPL from the system, ie to increase it's level by 10dB, requires 10 times the amplifier power. These are objective measurements and not open to debate.
In a hi-fi system changes to perceived loudness is something else. Generally speaking it is considered that the average person can detect a 1dB change in SPL as a change in loudness. However this is under test conditions and using test tones, in your front room, playing music, a 2dB change is required for the listener to interpret the increase as a change in loudness.
For most people, turning the hi-fi up 3dB on a music signal would be heard as a small but definite increase in loudness, it might take twice the power to increase the loudness by this amount, but it is definitely no-where near 'twice as loud'. In fact twice as loud is usually defined as +10dB, ie requiring 10 times the power, but this is a subjective evaluation. Modern tests suggest that the average person perceives a change in level of around 8dB to be twice as loud, but a different sample might well give different results.
