amplifier & speaker positioning in between??
hi all...
just want to us you guys how do you position your amplifier?? in between the speaker or at the side of the speaker??
heard that by positioning the amplifier at the side of the speaker would give better sounds in everything as no inteference between the speaker. however longer speaker cable required at least 5m & the longer the speaker cable will minimise the performance...
by placing the tv in between the speaker also could face the similar above?
any comments?
Don think amp positioning as you have said will make any differance, as long as you buy good speaker cable you will be ok. I spend 200+ on s cable other week, good stuff and wont matter the length.
Tv in between speakers will be ok as long as they are able too.
Speaker position is most important, dont worry if youve got your tv inbetween them!
